Hello! I'm working on a remote designer, and the touch screen keyboard keeps popping up. I've looked in every setting in the designer, but I can't see how to turn it off. I don't think it's a windows thing, because it doesn't come up in any other program or when I'm working in the gateway. I know I've turned it off before...but I can't seem to remember how. It's not urgent, and it's just annoying versus any sort of big issue. Sorry!
Can you check if you have "Emulate Touchscreen" enabled? That setting is found under the View menu in the Designer.
I actually only have "Reset Panels", "Panels", and "Toolbars" under the View menu.
Do you have the Vision module installed?
Edit: Actually, I think you might just be in a Workspace that only shows those options.
Ah, I see. I apologize, I didn't give enough information. That box isn't checked, but I'm also not working in Vision, I'm working with the Transaction groups and in Perspective.
Enabling Emulate Touchscreen in my Designer and bringing up the keyboard, I realized it's not the same keyboard you have.
What you're seeing is the Windows 10 touch keyboard. I can't seem to get it to show up no matter what settings I have but I don't have a touchscreen to test it on.
This post here has some steps to disable the touch keyboard. It should be a simple toggle in typing settings.
https://www.tenforums.com/tutorials/83312-turn-off-automatically-show-touch-keyboard-windows-10-a.html
That link helped! I got it, thank you! It was in the "Tablet" settings within the "Settings" menu.
