Touchscreen keyboard with Web Browser Module
Is there a way to enable the touchscreen keyboard with Web Browser Module?
Maybe:
https://docs.inductiveautomation.com/display/DOC79/system.gui.setTouchscreenModeEnabled
would have the information you seek to give it a try.
There is also a WEBDEV module, in addition to the Web Browser module.
More information may be found in the manuals and/or knowledgebase or via e-mail ( read policies first ) at:
https://support.inductiveautomation.com
Please also let others know about the results you get, good or bad. I am expecting your result would be much different if you had said in the Perspective module of Ignition 8.
Then there is what may be a broken link:
Or you might just need to be a 'logged on user" to use it.
'Inquiring minds want to know"- Thanks.
After trying with different web page (google.com) I realized that touchscreen keyboard actually works with the web browser module. It’s just the ‘TrakSYS’ web app we are trying to integrate that does not make the keyboard pop-up when touching a ‘text area’ element.
Thank you VERY, VERY much for saying so. I was just looking at the keyboard width setting under properties in the Vision Client Launch videos, ( Designer > Menu Project >dropdown Client User Interface ) & wondering if that had been adjusted. Instead, I will tag this post so that the TrakSYS issue might be added to the Knowledgebase.
( That is under the support menu )
https://support.inductiveautomation.com then choose Knowledgebase
It is truly good to know that others share, so that we can all learn.
