I have an application with V7.6.4 and Java 7 running with several Hope Industrial Touch screens connected to HP Thin Clients. Keyboard pop up works great any time a numeric or text input is required. Customer also have several desktop PCs connected as clients and they are complaining about the pop up keyboard anytime they need to input data.
Is there anyway to shut this off at the client side that does not have a touchscreen driver running, and if not can this be added as a feature request?
At the gateway, any client launched directly on gateway does not have the popup keyboard.
have you tried this script?
system.gui.setTouchscreenModeEnabled
Description
Alters a running client’s touchscreen mode on the fly.
Syntax
system.gui.setTouchscreenModeEnabled(enabled)
Parameters
boolean enabled - The new value for touchscreen mode being enabled.
Returns
nothing
Scope
Client
Examples
This example could be used on an input heavy window’s internalFrameActivated event to remove touch screen mode.
if system.gui.isTouchscreenModeEnabled():
system.gui.setTouchscreenModeEnabled(0)
See also:
perhaps you could turn off touchscreenmode based on ip address or computer name.
