Traceback deciphering
I know I'm late but I thought I would add this; I got this error and it turns out the reason for it was because I hadn't set my Ignition Designer to 'Read/Write' mode, so all read queries would work fine but I couldn't write data to the database. This was difficult to diagnose because of verbose error messages that in no way highlighted the main cause of the issue. Here is the error message I got, with the real reason 'Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.' about 2/3rds of the way down at the 2nd line that starts with 'Caused By:', very hard to find.
Java Traceback:
  File "<input>", line 107, in <module>
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:268)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO analysis_connect.oee_data (cell, area, machine, date, run_minutes, run_time_percent, idle_minutes, idle_time_percent, fault_minutes, fault_time_percent, output, target, performance, oee) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?), [triathlon cementless, beading, beading 1, Fri Nov 01 00:00:00 GMT 2024, 1194, 0.8292, 138, 0.0958, 79, 0.0549, 190.0, 216.0, 0.8796296296296297, 0.729388888888889], PowerBI2, , false, false)
	at org.python.core.Py.JavaError(Py.java:547)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:552)
	at org.python.core.PyObject.__call__(PyObject.java:494)
	at org.python.core.PyObject.__call__(PyObject.java:498)
	at org.python.pycode._pyx48.f$0(<input>:117)
	at org.python.pycode._pyx48.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1687)
	at org.python.core.Py.exec(Py.java:1731)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:611)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:599)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO database.table(cell, area, machine, date, run_minutes, run_time_percent, idle_minutes, idle_time_percent, fault_minutes, fault_time_percent, output, target, performance, oee) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?), [redacted, redacted, redacted, Fri Nov 01 00:00:00 GMT 2024, 1194, 0.8292, 138, 0.0958, 79, 0.0549, 190.0, 216.0, 0.8796296296296297, 0.729388888888889], redacted, , false, false)
	... 26 more
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:384)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:288)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:261)
	... 24 more
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO database.table(cell, area, machine, date, run_minutes, run_time_percent, idle_minutes, idle_time_percent, fault_minutes, fault_time_percent, output, target, performance, oee) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?), [redacted, redacted, redacted, Fri Nov 01 00:00:00 GMT 2024, 1194, 0.8292, 138, 0.0958, 79, 0.0549, 190.0, 216.0, 0.8796296296296297, 0.729388888888889], redacted, , false, false)
I've redacted some private info from this error message.
Most of use like verbose error messages, as they provide a great deal of troubleshooting information to help zoom right in to a problem. And they are typical for anything in the java world (all of Ignition). Learn to scan the "Caused by" chain whenever the first message isn't informative enough.
Nothing wrong with including plenty of information but there is one line in that 70 lines of error messages with the real problem that should obviously be highlighted.
It would take an AI built into Ignition to unravel tracebacks with that in mind. Now you know to inspect the "Caused by" lines. Carry on.
You also won't get this particular message in actual clients. Testing in real clients is necessary for many aspects of Ignition development.
(This is not your original topic, so if you want to whine further, you should start a new topic.) Done
loser
I've put up a feature request for better error logging, go give it a vote
Better formatting on error messages in script console | Voters | Inductive Automation
Sticks and stones, yada yada.
