Hi, i have a opc tag that we use for interacting with a plc. The tag is there to stop the machine from operating until the tag is set to false. I have a script that users use to set the tag to true or false depending on some circumstances.
Now i noticed the tag sometimes changes to false with no apparent reason. User does not run the script so i am wondering what did it.
Is there a way to check what caused the tag to change?
Hi Phil, thanks! I managed to track down tag writes i was looking for in the audit table. I cant actually tell what is doing that tag write.
Actor and Actor host are unknown, originating system is "project: MyProject".
We write to the tag from gateway events and few buttons in application. I can see that there are events that do have the actor and actor host, those are the ones that user does.
