I made a table with my transaction group.
I removed all the things in the table to replace them.
The values that populate my table seem to be from the initial tags.
I have disabled and saved, enabled and saved. The new tags do not seem to replace the old ones.
So now I want to delete that table.
How do I delete that table? (so I can make it over again)
DROP TABLE table_name ;
found it on the w3school thing
execute this pseudo sql query
drop table <tablename>
be very careful when using this and make sure you type in the correct table name etc. When you drop a table, it truncates the data first then drops the table, so if you drop a table by accident I don’t think you can reverse it.
I posted in features feedback a request that executing drop table would just rename the table the 7 days, and then delete it after that
so we could have 7 days of grace before we lose a database on a typo or something
ALTER TABLE table_name
RENAME TO new_table_name
Ignition has nothing to do with how drop table works, it only uses a driver to execute the query on the database. As @JordanCClark points out, you can just alter the table name, but if you don’t need it, it will still need to be dropped at some point.
Where do you run this query? I'm trying to rename a table from the Database Query Browser and get this error when I use that command: SQL error for "ALTER TABLE group_table RENAME table1": Incorrect syntax near 'RENAME
You're missing 'TO'
RENAME TO table1
This week, I started using:
SELECT *
INTO new_table
FROM old_table
WHERE 1 = 0;
and
SELECT *
INTO new_table
FROM old_table
and
INSERT INTO new_table
SELECT *
FROM old_table
Then until my pages using queries get switched over, I have both table names active.
