Hello All,
Just a quick question: is there an easy way to trend transaction group data (regular time series data) in perspective?
I mean something like the easy chart for vision.
Thanks,
Neill
Hello All,
Thanks,
Neill
V8.1 has the Perspective Power Chart
Just Setup a History Tag Provider using âDB Table Historianâ type and point it to your DB with the tables created by the Transaction groups.
Have a playâŚ
Thanks I managed to get my data into power chart tag browser.
However, charting a tag doesnât seem to work.
Data is definitely in my database table.
Additionally, the [timestampColumnName] is not automatically being defined despite the table using the default t_stamp column.
Iâll look into this further, hopefully this isnât a bug.
One thing to check⌠Make sure that the t_stamp column is the first column returned from your query. That order is important for the chart to accurately display data.
It would be in the query you have setup to build the table in MySQL that youâre using to create your DB historian.
I used a transaction group to make my table initially so youâd hope it set the table up properly to work within Ignition itself.
The power chart is still not working when I manually make the table in the workbench with just a t_stamp and index column, then adding a data column with a transaction group.
Power Chart GUI:
My database table:
What format must the t_stamp be?
I am currently using the inbuilt DateTime datatype.
Thoughts?
That certainly looks correct. Iâd take a peek at the gateway logs and also the browser console and see if anything jumps out at you. If thereâs nothing obvious in the logs/console, you can DM me a data export of the above image and I can try it out on my side.
I have just finished a support call and I was directed to use a timeseries chart with named queries.
The following video clearly show what I am trying to archive:
https://www.inductiveuniversity.com/videos/db-table-historian/8.1/8.1
Maybe this is a bug?
I got to the bottom of this.
You cannot use the perspective power chart without the tag historian module.
Maybe it should be renamed to: âtag historian power chartâ.
Yes, that is certainly a prerequisite to using that component. All queries for data are done via the tag historian. If that dependency isnât listed on the docs site, I will forward along a request to add it.
Edit: Just checked; weâre good to go on the docs site.
