Transaction Group Handshake and Store and Forward
Ignition 8.1.39
In my transaction group, I don't appear to be getting handshakes back.
I do NOT have the "Bypass Store and Forward" option set.
Which implies it IS using S&F.
Would using S&F cause handshakes not to be written?
Secondly, is it REQUIRED that the output item for the handshake be an INT4? or will any int type work?
Can I use a BOOL for the handshake item? Writing 1 on success and 0 on failure?
Thanks.
-Shane
If you are using S&F, handshake is meaningless. All it could possibly mean is that your record has been queued in S&F. It tells you nothing about future delivery to the DB.
(Yes, handshake tags can be booleans.)
