Hello,
I created a transaction group that will write a row on a database and when the row is inserted it has to call a store procedure that influence also that row.
What I did is to use the handshake of the trasaction group as trigger or the store procedure transaction group.
The problem is that the handhake is set to 1 (result ok) BEFORE the insert is commited and the store procedures runs BEFORE the insert as well. After the store procedure is finished I can see the new row in the database. I need that the insert is done strictly before the store procedure calling since it will use the new inserted row.
How can I solve this?
Thank you
Andrea
