Transaction Group ID
Hi guys,
working on a project with the release 7.9.6,
I’m trying to let the transaction group create a database table,
I noticed that even if I take off the “use custom index column”, Ignition still create the index column.
Is there any way to exclude the index column at all ?
No. But if you turn that checkbox back off after the table is created, you can delete that index column manually. Be sure to manually set up a different primary key, or performance will suck.
Ok thanks.
What i was looking for was to load a dataset from a sql query and then bind this dataset to a table and a chart.
The problem is that the chart require a dataset where the first column is a DATETIME, so for simplicity I was trying to let the transaction group create a table built like this, whit no ID and whit a first column as DATETIME.
At this point i recon that the only reason it will be to filter my column within the sql code.
Thanks for your time.
