I have a few transaction groups that are supposed to be running once per day. This table is used in some custom reports. But 5 or 6 times a month I find duplicate entries in the table.
I have the transaction group setup to run once per day. It does this by having the “Excecution Scheduling” set to timer at 1 second intervals. There is a “Run-Always Expression Items” trigger that is an expression and checks to see if the current time is within the 3 a.m. hour and if it is then evaluates to true. Within the Trigger tab of the transaction group I have the “Only execute once while trigger is active” option checked. As I understand it this should cause it to execute once a day within the 3 a.m. hour. But I’m still getting duplicate rows in the table every so often.
I can’t seem to find the circumstance that causes the duplicates. I wonder if it happens when the gateway is restarted. Most of the time there is also a 3rd entry for the same timestamp in the table where everything except the timestamp is null. It would look something like this…
See below for settings for the transaction group.
