Hello, I am facing an issue with the transaction group. It was working correctly but after some days, I received an alert in store and forward which indicated that I passed the total Quarantined. I deleted the data in disk cache and tried again but still facing the issue of being unable to start. Maybe it's because my version of Ignition is not stable (trial mode) or still exist in the directory ??
Do you have a license for the SQL Bridge module? If not, the transaction groups will stop running when the trial ends.
If your gateway is showing the "License Incomplete" banners, you should inspect your list of installed modules. The ones that are in trial mode should be removed, unless you need them, in which case you will have to buy their license.
Thanks! I'm new to this platform and don't have a license, so this project is just for core test. Will could affect my grade? I did store some data and test my report.
You should ask the training group. No assistance with core test issues are permitted on this forum. None whatsoever.
