It’s using the default “root” MySQL account and as best I can tell all is enabled with it. It’s the only MySQL account used. ???
The log has an error when I try to start the group:
java.lang.AbstractMethodError: com.mysql.jdbc.Connection.getSchema()Ljava/lang/String;
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.refreshTableState(DBTableSchema.java:187)
at com.inductiveautomation.factorysql.groups.AbstractTableItemGroup.checkTableStructure(AbstractTableItemGroup.java:166)
at com.inductiveautomation.factorysql.groups.AbstractTableItemGroup.prestartCheck(AbstractTableItemGroup.java:115)
at com.inductiveautomation.factorysql.groups.AbstractGroup.startExecution(AbstractGroup.java:266)
at com.inductiveautomation.factorysql.ProjectRunner.loadGroupResource(ProjectRunner.java:358)
at com.inductiveautomation.factorysql.ProjectRunner.loadProject(ProjectRunner.java:284)
at com.inductiveautomation.factorysql.ProjectRunner$1.run(ProjectRunner.java:204)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
