I've noticed that when I create a TG and select a table from the drop down list, that: IF the schema is different than dbo the selected table cannot be found when executing the TG.
Now, when I type in the schema name, such as production.table_1, then the table is "visible" by the TG, BUT, there are no fields available in the drop down boxes for each OPC/Group item to configure. I have to manually type the field/column name that I want that tag's value to be stored to.
Is there a fix for this? Thanks
