Here in this place under transaction groups, if I type the value marked in the red circle at the image, instead of select it from the big list of tags/addresses I get an Error message. is there a way to type it instead of select it? type in this case is faster..
thanks
A little more context will be useful here :
- about your tags : what is the meaning of SQL/DBows and SQL/SQLows1 ?
- when you type manually the tag in red circle, do you use comme (,) instead of (.) ?
-That SQL/DBows is the data array that comes from a Query
-Yes comma, ni fact I am only changing the first value and then I get the error box
