Transaction Group Unable to Start, task problem
I have a problem with a transaction group that doesn't start. The settings of the group are good, I compared with other groups that are working well. In the logs I have this error:
java.lang.IllegalArgumentException: There is already a scheduled task for sql bridge.swecos_pcp.mill5_milling limits.mainexec
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine.register(BasicExecutionEngine.java:407)
at com.inductiveautomation.factorysql.groups.AbstractGroup.startExecution(AbstractGroup.java:360)
at com.inductiveautomation.factorysql.ProjectRunner.loadGroupResource(ProjectRunner.java:286)
at com.inductiveautomation.factorysql.ProjectRunner.lambda$onResourcesModified$2(ProjectRunner.java:174)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.inductiveautomation.factorysql.ProjectRunner.onResourcesModified(ProjectRunner.java:174)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycle$LifecycleResourceListener.resourcesModified(ProjectLifecycle.java:176)
at com.inductiveautomation.ignition.common.project.AbstractProject.notifyResourceListeners(AbstractProject.java:351)
at com.inductiveautomation.ignition.common.project.AbstractProject.updateEffectiveState(AbstractProject.java:153)
at com.inductiveautomation.ignition.common.project.RuntimeProject.applyChange(RuntimeProject.java:274)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.lambda$updateOrStartAffectedProjects$5(ProjectLifecycleFactory.java:185)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.updateOrStartAffectedProjects(ProjectLifecycleFactory.java:165)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.projectUpdated(ProjectLifecycleFactory.java:143)
at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.doProjectUpdatedNotification(BaseProjectManager.java:1055)
at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.lambda$fireProjectUpdated$25(BaseProjectManager.java:1005)
at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.lambda$submitToQueue$22(BaseProjectManager.java:983)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:239)
I don't know what is this task problem, I tried to check in the gateway about that but I didn't find anything. If you have any idea please let me know
