Transaction groups, block group, item data type dataset
Hi to All,
I am sorry if this question already exists, I couldn’t find it.
I have a memory tag which data type is dataset (two columns and xx rows). I wont to use transaction groups as I will insert data from dataset tag in SQL database (table with 2 columns).
Is it possible?
I have tried a lot of different configurations and I didn’t succeed.
Thanks!
You cannot do this. Datasets cannot be stored to history nor included in a transaction group. If you must record a dataset, you will have to write a custom script to insert its contents to the DB row by row.
Ok. Thank you very much on your answer.
I am not surprised, but possibility to set data type to Data Set made me think that is possible.
Thanks!
But with block group I do not have to insert row by row in DB I can insert an Array, for example of strings?
Did you figured it out? I having the same question. I wish there was a system.db function to do a block transfer.
You can construct multi-row insert statements in scripts if your DB supports such syntax. The key is making sure the final list of arguments matches the number of substitution points in your SQL.
Will give that a try. I am using mysql as my database.
