Greetings - shifted some transaction groups from one project to another and all started up ok.
But now some groups are failing with
1:30:50 AM B1_CIPToBoiler1 Error during group execution.
com.inductiveautomation.factorysql.evaluation.EvaluationException: java.lang.Exception: Unable to add data to memory buffer, buffer full.
at com.inductiveautomation.factorysql.evaluation.itemexecutors.SRHistoryRowExecutor.postEvaluate(SRHistoryRowExecutor.java:61)
at com.inductiveautomation.factorysql.evaluation.itemexecutors.ExecutorCollection.evaluate(ExecutorCollection.java:81)
at com.inductiveautomation.factorysql.evaluation.itemexecutors.ExecutorCollection.postEvaluate(ExecutorCollection.java:72)
at com.inductiveautomation.factorysql.groups.AbstractItemExecutionGroup.onTriggerPostEvaluation(AbstractItemExecutionGroup.java:753)
at com.inductiveautomation.factorysql.groups.AbstractGroup.evaluate(AbstractGroup.java:472)
at com.inductiveautomation.factorysql.groups.AbstractGroup$1.run(AbstractGroup.java:414)
at com.inductiveautomation.factorysql.evaluation.GeneralGroupExecutor.run(GeneralGroupExecutor.java:169)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$SelfSchedulingRunner.run(BasicExecutionEngine.java:491)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:573)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.Exception: Unable to add data to memory buffer, buffer full.
at com.inductiveautomation.ignition.gateway.history.stores.MemoryStore.insertInBuffer(MemoryStore.java:156)
at com.inductiveautomation.ignition.gateway.history.stores.MemoryStore.syncdStoreData(MemoryStore.java:70)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractStore.storeData(AbstractStore.java:225)
at com.inductiveautomation.ignition.gateway.history.stores.MultiStageStore.syncdStoreData(MultiStageStore.java:150)
at com.inductiveautomation.ignition.gateway.history.DefaultStoreAndForwardEngine.storeData(DefaultStoreAndForwardEngine.java:173)
at com.inductiveautomation.ignition.gateway.history.HistoryManagerImpl.storeHistory(HistoryManagerImpl.java:156)
at com.inductiveautomation.factorysql.evaluation.itemexecutors.SRHistoryRowExecutor.postEvaluate(SRHistoryRowExecutor.java:42)
… 15 more
Anything one does…eg create a new group, remove elements, recreate elements etc all fail with same error.
After reboot - all run for a short while then same issue.
These groups were running for months beforehand so am confident the issue is not with the setup.
Where to from here?
