Transaction Groups Disabling Themselves After Gateway Restart
I have two different projects which use transaction groups. I have had to restart my Ignition gateway a handful of times over the past few months.
I have noticed that after restarting the gateway, the transaction groups in those projects are no longer running until I disable and re-enable the projects. Is there any way to avoid having to do this each time?
It is a risk to production since it relies on our engineering staff remembering to disable and re-enable the projects after a restart.
You should open a support ticket. I vaguely recall others mentioning similar problems, and support can help you tie it down. (I can't recall if this is already fixed.)
Is there only one tx group per project in this case?
The recent thread was Transaction group stuck 'unable to start' after reboot, no way to monitor or auto-recover? - Ignition - Inductive Automation Forum
The recent thread is mine. Multiple transaction groups in one project. I was told that a bug ticket has been put in for this.
Yes there are multiple tx groups in each of my projects.
