I have a problem in standard transaction for recording the setup of machine.
I record it when one value of tags change.
I see the problem when I switch off and switch on the machine(server opc connection) because the transaction record double time the equal value.
Is there a system to avoid it?
Ah ok but this option is possible to active when I tick "Execute this Group on a trigger" and after I decide to use one tag.
Is it not possible with all tags?
How can I use trigger in the best mode?
