The group setting “evaluate on change” does not seem to work. I have 1 item in a group that I know is not changing, but the group triggers and writes on the update rate regardless. I am wondering if it is also looking at the t_stamp or quality code. I used the custom setting and still got the same results.
Also a minor thing, by default the “delete by” box selects ms. I think this is from the legacy import. If I add a new group it doesn’t do this. When you drop it down it has day,month,year and they select fine.
Bump
Ah! Sorry, I thought I had replied to this. Indeed, there was a problem, and it’s been fixed for 7.0.2 which will be released very shortly.
Regards,
