When editing a group item and selecting to browse the opc servers(Doesn’t matter if it is OPCUA or Kep) the following fault occurs and won’t let you browse.
java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCTreeModel.<init>(OPCTreeModel.java:29)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCBrowserBasePanel.itemStateChanged(OPCBrowserBasePanel.java:144)
at javax.swing.JComboBox.fireItemStateChanged(Unknown Source)
at javax.swing.JComboBox.selectedItemChanged(Unknown Source)
at javax.swing.JComboBox.contentsChanged(Unknown Source)
at javax.swing.AbstractListModel.fireContentsChanged(Unknown Source)
at javax.swing.DefaultComboBoxModel.setSelectedItem(Unknown Source)
at com.inductiveautomation.ignition.designer.gui.AbstractProfileOptionDropdown.setSelectedItem(AbstractProfileOptionDropdown.java:69)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCBrowserBasePanel.setProvider(OPCBrowserBasePanel.java:133)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCChooser.createContentPanel(OPCChooser.java:62)
at com.jidesoft.dialog.StandardDialog$DefaultStandardDialogPane.createContentPanel(Unknown Source)
at com.jidesoft.dialog.StandardDialogPane.initComponents(Unknown Source)
at com.jidesoft.dialog.StandardDialog.initComponents(Unknown Source)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCChooser.chooseOPCItem(OPCChooser.java:144)
at com.inductiveautomation.ignition.designer.sqltags.editor.ChooseOPCButton.actionPerformed(ChooseOPCButton.java:57)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
Ignition v7.0.1 (b4446)
Java: Sun Microsystems Inc. 1.6.0_11
