I fudged a workaround that got me out of trouble…if the width was 0, I set it to 1 and then applied the transform.
Could not set width to 0 afterwards due to the disappearance issue, but it worked for what I needed and saved my hours of rejigging components.
I’ve posted my very, very ugly code below in case it is of use to someone.
import pickle
def storePosition(object):
#root container to begin from
root=object
#now get all components
components=[]
objs=root.getComponents()
descend=[]
for c in objs:
if c.getName():
components.append(("",c))
descend.append(("",c))
while len(descend)>0:
objs=descend[0][1].getComponents()
for c in objs:
if c.getName():
if descend[0][0]=="":
prefix=""
else:
prefix=descend[0][0]+"/"
components.append((prefix+descend[0][1].getName(),c))
descend.append((prefix+descend[0][1].getName(),c))
descend=descend[1:] #drop one of the list
print len(components)
#create dictionary of name,position and size
d={}
for cc in components:
c=cc[1]
try:
x=c.getX()
except:
x=None
try:
y=c.getY()
except:
y=None
try:
w=c.width
except:
w=None
try:
h=c.height
except:
h=None
try:
rx=c.relX
except:
rx=None
try:
ry=c.relY
except:
ry=None
try:
rw=c.relWidth
except:
rw=None
try:
rh=c.relHeight
except:
rh=None
try:
ang=c.angleDegrees
except:
ang=None
if cc[0]=="":
prefix=""
else:
prefix=cc[0]+"/"
d[prefix+c.getName()]=(x,y,w,h,rx,ry,rw,rh,ang,type(c))
print prefix+c.getName(),(x,y,w,h,rx,ry,rw,rh,ang,type(c))
out=pickle.dumps(d)
path = system.file.saveFile("save_Positions.txt")
if path != None:
system.file.writeFile(path, out)
def restorePosition(object):
path = system.file.openFile('txt')
if path != None:
data=system.file.readFileAsString(path,"US-ASCII")
try:
data=pickle.loads(data)
except:
system.gui.errorBox("Error reading file "+path)
return
for key in data:
k=key.split("/")
co=object
for kn in k:
try:
co=co.getComponent(kn)
except:
pass
if co:
name=co.getName()
#print key,":",name
if name!=k[-1]: #we may not be a component so stay stuck up the tree
continue
x,y,w,h,rx,ry,rw,rh,ang,typ=data[key]
#do things one at a time
if x!=None and rx==None:
#if rx==None:
#system.gui.transform(co,newX=x,newY=y,newWidth=w,newHeight=h)
system.gui.moveComponent(co, x, y)
system.gui.resizeComponent(co, w, h)
if rx!=None:
if (co.relWidth==0 or co.relHeight==0):
print "OFFENDING object found"
print name,x,y,w,h,rx,ry,rw,rh,ang,str(typ)
if co.width==0:
co.setRelWidth(1) #force it to have a width or height
elif co.height==0:
co.setRelHeight(1)
#system.gui.transform(co,newX=rx,newY=ry,newWidthr=w,newHeight=rh)
#system.gui.moveComponent(co, int(rx), int(ry))
#system.gui.resizeComponent(co, int(rw), int(rh))
co.setRelX(rx)
co.setRelY(ry)
co.setAngleDegrees(ang) #force it to have a width or height
if rw==0:
co.setRelHeight(rh)
#co.setRelWidth(rw)
elif rh==0:
co.setRelWidth(rw)
#co.setRelHeight(rh)
else:
co.setRelWidth(rw)
co.setRelHeight(rh)
else:
name="NOT FOUND"
