Translating Data in Table Components
Can the data inside of tables be translated?
If so, how can this be done? The only property that I could find that would let me do this was the Translation List property on the Table Customizer, but recreating each translation pair when I already have translations in my translation manager does not make any sense, so I’m hoping there is a better way.
We assume your data coming in is already the way you want it. Depending on the source, you can either use system.util.translate to translate your data or you can use named queries to dynamically change the source of your data.
