Translation from English to Norwegian based on session.props.locale using Translation Manager
I have a table component and have added some translations in the translation manager how can I make it so that when I change the locale the table header and details change accordingly
In the last versions of Ignition this works automatically.
In the older you have to bind the column title property to an expression and use translate()
can you provied an example for the translate
also I am using version8.1
