Here is the interface pop up that I see when I click on “Add Language”. It’s very small and hard to select multiple languages. I cannot resize it for some reason.
[attachment=0]TranslationManagerAdd.png.png[/attachment]
Thanks, as I suspected, for some reason it’s just doing it for you. This is what it looks like on all the machines I’ve tried:
[attachment=0]addlang.PNG[/attachment]
What version of java, and what os, is this designer on? We can probably just set a minimum size on this to get around the problem.
Thanks,
Mine looks the same as Duffanator.
JDK 8u5 64 bit
Windows 8.1 u1
Ignition 7.7.0 beta 3
I haven’t tried it on another computer yet, just my development server:
Java: build 1.8.0_05-b13
OS: Microsoft Windows Server 2003 R2, Service Pack 2
Ignition: 7.7.0-beta3 (32-bit)
Mine looks like Colby’s
Windows Server 2012 R2 Essentials.
Java 8u5
[quote=“Paullys50”]Mine looks like Colby’s
Java 8u5[/quote]
And right when I was going to blame java 8!
I’m sure it’s easy enough to fix with a minimum size setting.
[quote=“Kyle Chase”]Mine looks the same as Duffanator.
JDK 8u5 64 bit
Windows 8.1 u1
Ignition 7.7.0 beta 3[/quote]
Same here, only I’ve tested on Win7 SP1 64bit VMWare 10 virtual machine.
We’ve got that fixed for -rc1
