Translation Manager and punctuation problem
I need your help about using tra Translation Manager.
This are the translation words and settings:
Why if I translate this
This is the result?
As you can see the : are missing.
Thank you for the help.
Would not : be considered punctuation?
If is deselect "Ignore Punctuation" the translation doesn't happen anymore, looks like if is not selected the string doesn't match
My guess is it matches because you are ignoring punctuation, then it replaces it with your alternate which does not have the punctuation.
Seeing as the label has a border, I would just scrap the colon.
Yeah could be, but this means that we have to do the translation twice..with and without the : ?
I mean if this is the "solution" I can do this but it looks a little bit weird.
No there's no border of the label, this are the settings of the style
I mean whatever component the numbers are in. The colon does not seem necessary to me.
Ok sorry, yes probably you're right in this case, my question is generic just to understand the better way to move on with the translations.
Thanks for the help!
A work around is to use a separate label that holds only the colon. Then it would be ignored and untouched.
