When translation manager is used to translate the header of power table, it shows garbled code. The date of power table is bound with SQL query. However, when I manually add the column of data, it can be translated normally. How should this problem be solved?
When you see empty boxes instead of characters, that’s a font issue – the chosen font knows what the character is, but doesn’t have the ability to display it.
Yes, I understand what you mean, but this problem seems to be related to the binding of power table to SQL query data source. Among all the texts, I choose the same font, but only the column names of power table bound with SQL query display garbled code. I know how to solve the font problem in the designer, but dynamic power I can’t find a solution for the table column name, which seems to be related to the control.
