Translations Manager resource
Good morning,
I'm using the this resource but I encounter a problem
[Ignition Exchange](https://Translation manager)
I have Italian (it-IT), Chinese (zh-Hans) and English (en-US), when I add a term in Italian and English I have no problem, when I add the Chinese term and I save nothing happen.
Anybody else had this kind of problem?
You should probably ping the author of the resource.
You're right @Arnaud_Declerck Justin, actually I sent a message time ago with no luck.
Thank you
Hi, i saw you message.
I'm just currently in commissioning and don't have that much time.
I can take a look around the end of august.
I would suggest checking is some special character in the chinese language make the script crash.
Regards
Hi Arnaud, nice to read you.
Is not a problem, I understand that you are busy now and I don't want to waste your time so if you will have some time to check it out in the future I'll appreciate it.
I'll try to figure out about the special character but with all the words that I try to insert I have the same problem, what I can say that looks strange for me is this, you can see that zh_Hans is written in a strange way.. I wonder if I choose the "wrong" chinese code..
In the last couple hours I made some tests and I can confirm you that the problem is zh_#Hans, if I use zh-CN I can add all the chinese words that I have.
that _# seems very out of place, the language alternatives should be seperated with -
