Hi guys
I’m a integrator of glass furnace plants. In this plants we have a lot of measure, valves and motors. I set up factories around the world. It’s nice to “ignition” doing graphics with drag and drop.
But I have a problem with Tag Browse Tree.
For the operator it is difficult to find the tag you need when you have 800 tags and the P&D. Search “TT1001LT” is more difficult to find “Temp. Line 1 Zone 1 Left Top”.
I thought a solution, but I can not do. In my udt’s I have a QueryTag connect to a table in my database, the result is the description of the tag. For example Name udt: Measure1, QueryTag:Temp. Line 1 Zone 1 Left Top. Could it be that in the tree browser to view the tag tagexpression and not the tag development?
I’m looking for a solution the same a file
Thank for you help and idee
j.abrante
Could you make a dataset or a hidden table of your tags through a script and use the Tree View Component?
Hi
I had thought that option. But I need the table is dynamic, and do not know how I can make a dynamic table with the Historical Tags.
You know?
Resolved
I used the template “AdHoc Trend With Annotations” in “Tag Tree-> scripting,> Property change” I put this code.
In the UDT, I have a Query Tag that will project a table where I have all descriptions and tags of P & D. I select the tag in the code
if event.propertyName == "inData":
newData = []
headers = ["path", "text", "selectedText", "tagPath", "querymode"]
for row in system.dataset.toPyDataSet(event.newValue):
tagPath = row["tagpath"]
queryMode = row["querymode"]
parts = tagPath.split("/")
tagName = parts[-1]
parts.pop()
#Start Search TagDescription
tagforDescription = parts[-2]
strTagDescription = str(system.tag.read("/".join(parts) + "/TagDescription"))
splitTagDescription = strTagDescription.split(",")
TagDescription = splitTagDescription[-3]
TagDescription = TagDescription.replace("[","")
#End Search TagDescription
#Start Search TagPyD
strTagPyD = str(system.tag.read("/".join(parts) + "/TagName"))
splitTagPyD = strTagPyD.split(",")
TagPyD = splitTagPyD[-3]
TagPyD = TagPyD.replace("["," ")
#End Search TagPyD
#Start Traslation
for i in range(len(parts)):
parts[i] = system.util.translate(parts[i])
#End Traslation
parts[-1] = TagPyD + "-" + TagDescription
newData.append(["/".join(parts), tagName, tagName, tagPath, queryMode])
event.source.data = system.dataset.toDataSet(headers, newData)
