We have been qualifying MySQL 5.7 and found that the bit type is handled differently in Ignition for bit(n) where n>1. We went back and checked MySQL 5.6 and found this also to be the case.
Assume a create table statement such as
create table test (id int(11), b1 bit(1) default b'0', b3 bit(3) default b'111')
when I populate this table with a few rows and issue the query
select * from test
I get the following in MySQL Workbench
1, 0, 7
2, 0, 7
3, 0, 7
In the Ignition database query browser, I get something like
1,false,[B@1dcaaa10
2,false,[B@4dc713c3
3,false,[B@709c8237
I get the same result with the following query.
select id,b1,cast(b3 as binary) from test
If I use the following, the string for the third column is empty.
select id,b1,cast(b3 as char) from test
I tried using the same driver with a Java program, and ResultSet.getString(“b3”) returns “7”.
Ignition 7.8.2
mysql connector/j 5.1.38
java 1.8.0_91
