I think I may have found a bug, or maybe I’m doing something you aren’t supposed to do.
In FactorySQL, I have a folder with five groups. Each group represents different parts of the plant, and each group is set to execute on a trigger. During commissioning, I only wanted to start two of the groups, so I did a multi-select with CTL-click. When I do this, the “Trigger on item” field goes blank on the groups I select. The same thing happens if I select the two groups with a fence. The triggers are definitely gone, because the groups error out when I start them. I have to manually set the trigger items again to fix this.
Just thought I’d bring it to your attention.
