Hello,
I have script to generate xml file:
from xml.etree.ElementTree import ElementTree
import xml.etree.ElementTree as etree
import xml.etree.cElementTree as ET
value1 = system.tag.read(“Torque/Torque_IP033/LTR_TIMESTAMP”).value
value2 = system.tag.read(“Torque/Torque_IP033/LTR_TORQUE_STATUS”).value
value3 = system.tag.read(“Torque/Torque_IP033/LTR_TORQUE_VALUE”).value
root = ET.Element(“root”)
doc = ET.SubElement(root, “doc”)
ET.SubElement(doc, “Date”, name=“Today”).text = str(value1)
ET.SubElement(doc, “Torque”, name=“Status”).text = str(value2)
ET.SubElement(doc, “Torque”, name=“Status”).text = str(value3)
tree = ET.ElementTree(root)
tree.write(“C:\CSV\person4.xml”)
I would like to run this script every time the time stamp value change. I can run it on the button trigger but I would like this to be triggered always when tag value change regardless if client is opened or not.
Regads
Pawel
