Not sure if this is the right thread.
I am trying to connect Kepserver to Ignition as an OPC Ua device.
They are on different servers Ign on x.x.x.144 and Kep on x.x.x.137.
When I try to add it to Ignition OPC device connections I get
Message= io.netty.channel.ConnectTimeOutException
as an error.
I can see the port on the Kep is 49320.
Not sure what to look for.
Also, I see in your previous post you say there is a restart needed. Do you mean Ignition GW or KepServer?
I moved your post because the topic it was originally in was about making connections the other direction: Kepserver as the client, Ignition as the server.
You have a standard networking problem. It's most likely a firewall on one of the servers not allowing the connection to be made.
Thanks for the quick reply. I thought that might be the case and have asked our IT security to take a look.
