Creating a new application using a previously backed up gateway project. The previous gateway had more than one OPC server installed and this current gateway install only uses the built in OPC-UA.
I am trying to delete the two not required, but am stuck with this message.
You can’t remove those through the gateway interface without having the corresponding module that added it installed.
It looks like you need both the COM module and the OEE module(s).
Alternatively, you can call support and they can do some ninja internal DB queries that will remove them.
