Trouble running an alarm notification block named query
I have two projects with one containing all my scripts, named queries, etc. I am trying to get an alarm notification block calculatedRoster running using a named query from the parent. I see the query within the child project that was inherited from the parent. when i run the same script in the console it returns the results I am expecting. I put essentially the same into the calculatedRoster script and I get no errors in the script. When I try to test the notification block I get the following issue:
org.python.core.PyException: java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: Project name required for script execution: the Gateway Scripting Project is not set.
I went into the gateway and made sure the gateway scripting project was set to the parent. I have also tried changing my runDBQuery to include and not include the parent in the path..including "Parent/namedquery" and also "Parent", "namedquery".
What am I missing?
The script console is Vision scope. Notification pipelines are Gateway scope. The function argument requirements are different. Look closer at the docs.
Are you talking about the system.db.runquery function?
No, because that doesn't run named queries.
I meant system.db.runNamedQuery
Yes. Look closer at the docs, in regards to scope.
Thanks. I did. I no longer get that message because I included the project name in the query. I now get a error telling me its getting a string instead of a dictionary.
You'll now have to share your code. Please format it for readability.
(Please see https://forum.inductiveautomation.com/t/wiki-how-to-post-code-on-this-forum/77831.)
