could you post the link for javadoc with this method ?
have not the last sdk javadoc ? only 7.7.8 seems to be available.
With IntelliJ/Maven, can we build right now the module with this add.
Need to very quickly upgrade 2 modules for 7.8.3 with FREE licence.
What is the code to add for a FREE module :
into public class ModuleHook extends AbstractDriverModuleHook
for a module based with AbstractDriverModuleHook ?
into public class AuditLogSplitterGatewayHook extends AbstractGatewayModuleHook
for a module based with AbstractGatewayModuleHook ?
I have a compilation error.
When I decompile interface GatewayModuleHook into intellij,
I don't find isFreeModule() method described into 7.7.8 javadoc.
data gathered from maven are from SDK 7.7.1...,
I use :
and
How to use 7.7.8 or 7.8.3 to be able to compile the module with isFreeModule() !!!
if I change the sdk version to 7.7.8 into my pom, I have thhe following compilation error
I downloaded module-signer project zip file. When I extracted the zip file and run the “mvn clean package” command as you mentioned, I found this type of error shown in below. How to solve that case.
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 3 source files to C:\Users\thanthm\eclipse-workspace\module-signer-master\target\classes
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 01:34 min
[INFO] Finished at: 2020-12-11T11:46:16+08:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project module-signer: Fatal error compiling: invalid flag: --release -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException.
yes. I can compile the module-signed project with jdk 11. But the module can not used because Module “client-designer-gateway-archetype Ignition Module” requires at least Ignition version 8.0.0 (b0). May I know how to signed the module for ignition verion 7.9.16. Thanks for your guidance.
