Trouble with Modbus tags
Hello, I'm working on a project to set up power monitoring station in Ignition. I'm having trouble connecting to tags. My device is connect to the OPC network. I read somewhere that I might have configured the device wrong from the start. The device I'm trying to connect to is the PowerLogic ION 7550.
Here's the mapping I found for it
and here's the error I keep getting in ignition
Any help would be amazing
Check your unit ID setup for the modbus comms, IE if it is 1 instead of 0, try this
[PWM1]1.HRUS40150
Try these addresses:
  • HR150
  • 1.HR150
  • 1.HR40150
This form is amazing. It worked and thank you for the help!
Which one :smiley:
Technically both. however, the address that didn't have the 40k in front was the value I wanted
the 1.HR150 for clarification
