I every one, I tried to connect camera ip with ignition, I dont know the url, some one help me…
I can´t see the model DH-SD50230UN-HNI on the next page
https://www.ispyconnect.com/camera/dahua
You can use VLC to try out a few different URL, sometimes even if your exact camera isn’t listed the URL will work anyway. One thing to keep in mind the IP camera viewer component will not recognize a RTSP stream. If you need to use a RTSP stream check out This post
