I'm trying to add an AB micrologix 1500 PLC, the only selection is 1000 to 1400 for the micrologix. I've tried all the AB drivers with no luck. Could sure use a suggestion or 2. Thanks
MLX 1200 and 1500 are only partially supported. You should be able to connect and manually address tags, but browsing doesn't work.
Using the micrologix driver? I keep getting "Determining Protocol" message but no connection.
Yep. Maybe there's a connection path you need? Try 1,0 even just to force it into bridged EIP mode.
edit: oh, also try the "disable processor browse" setting.
Tried both suggestions, still getting the same message. "Determining Protocol"
