Trying to Add Row in the Template Repeater Dataset
Trying to create dynamic template repeater through scripting which works fine at some extent. But, can’t seem to add new Row:
Current State of template parameters property of Repeater :
Initialized Value of self.templates - Dataset [4R ⅹ 7C]
[<Row:7 columns>, <Row:7 columns>, <Row:7 columns>, <Row:7 columns>]
Trying to add Following Row:
remix_compound_id,  Remix Compound,  4, -1,  Dataset [1990R ⅹ 2C], False, ''
But, when I try to Either add with
System.dataset.addRow or system.dataset.toDataSet(column, rows)
it errors out as :
java.lang.ClassCastException: java.lang.ClassCastException: class org.python.core.PyObjectDerived cannot be cast to class org.python.core.PySequence (org.python.core.PyObjectDerived and org.python.core.PySequence are in unnamed module of loader java.net.URLClassLoader @38a26330)
Any Idea ?
Many thanks in Advance
Anyone ?
Can you post the dataset behind the template repeater and the script you’re using to add a row?
@zacht, Amm, I just realized I was trying to append list instead of list of lists !!
Got it working, thanks !!
