Hello all,
I’ve been trying to copy some of the functionality of our old SCADA system into ignition. I have been playing around in the Script playground trying to get his to work and it’s basically a series of SQL commands that place data from our powerstations into a database. I will include a small snippet of the code in this post. I am really just trying to see if I should just copy what the script is doing using transaction groups (which is what I would like to do) or make small changes to the code so that it will run in Ignition. Any help is greatly appreciated.
Here is a small section of the code:
FUNCTION PSMWeb_Dump()
INT i;
INT hSQL, ISet,iexec, iEndofDayHour, iEndofDayMin, iEndofDayPeriod;
STRING ThisTime;
STRING ThisDate;
STRING Yesterday;
REAL rTotalkWHrs;
!Calculate today’s date in the format yyyy-mm-dd
ThisDate = IntToStr(DateYear(TimeCurrent(),1)) + “-” + IntToStr(DateMonth(TimeCurrent())) + “-” + IntToStr(DateDay(TimeCurrent()))
!Calculate yesterday’s date in the format yyyy-mm-dd
Yesterday = IntToStr(DateYear(DateAdd(TimeCurrent(),-86400),1)) + “-” + IntToStr(DateMonth(DateAdd(TimeCurrent(),-86400))) + “-” + IntToStr(DateDay(DateAdd(TimeCurrent(), -86400)))
! Time is a number between 0…95 (which corresponds to each 15 minute period in a day)
ThisTime=IntToStr(TimeHour(TimeCurrent())*4+TimeMin(TimeCurrent())/15);
iEndofDayHour = 0;
iEndofDayMin = 0;
iEndofDayPeriod = ((iEndofDayHour*4) + (iEndofDayMin/15));
! Connect to the SQL server directly
hSQL = SQLConnect(“Driver={SQL Server};Server=(LOCAL);Database=psmSQL;Uid=PSMWeb;Pwd=killjoy8;”);
!Generator 11
G11_Cal_Mwhacc = G11_Cal_Mwhacc + ((G11_A200_kW_PVR*G11_sGCB_CL)/1000/4)
!----------------------------- 15 MINUTE DATA ------------------------------------
! STATION EXPORT KW
ISet=SQLSet(hSQL, "INSERT INTO [psmSQL].dbo.CitectData ");
SQLAppend(hSQL, "(PowerStation, ObjectID, PSMTag, PSMDate, PSMTime, PSMValue)");
SQLAppend(hSQL, " VALUES ");
SQLAppend(hSQL, "('0890',100,'StnkW','" +ThisDate+ "',"+ThisTime+","+IntToStr(STN_EXP_KW)+")");
iexec=SQLExec(hSQL, "");
IF iexec <> 0 THEN
TraceMsg("Period "+ThisTime+": SQL Error Inserting Station Export kW. SQL Error:"+ SQLErrMsg());
END
SQLEnd(hSQL);
! GENERATOR 11 INSTANTANEOUS KW METERING
SQLAppend(hSQL, "('0890',11, 'GenkW','" +ThisDate+ "',"+ThisTime+"," +IntToStr(G11_A200_kW_PVR)+")");
IF iexec <> 0 THEN
TraceMsg("Period "+ThisTime+": SQL Error Inserting GM 1 kW. SQL Error:"+ SQLErrMsg());
END
SQLEnd(hSQL);
! GENERATOR 11 ENGINE HOURS
SQLAppend(hSQL, "('0890',11, 'EngHrs','" +ThisDate+ "',"+ThisTime+"," +RealToStr(G11_TEM_RHRS,12,3)+")");
IF iexec <> 0 THEN
TraceMsg("Period "+ThisTime+": SQL Error Inserting GM 1 Engine Hrs. SQL Error:"+ SQLErrMsg());
END
SQLEnd(hSQL);
! GENERATOR 11 MWh
SQLAppend(hSQL, "('0890',11, 'GenMWh','" +ThisDate+ "',"+ThisTime+"," +RealToStr(STN_G11_KWH/1000,12,3)+")");
IF iexec <> 0 THEN
TraceMsg("Period "+ThisTime+": SQL Error Inserting GM 1 Engine MWHrs. SQL Error:"+ SQLErrMsg());
END
SQLEnd(hSQL);
! GENERATOR 11 MWh
SQLAppend(hSQL, "('0890',11, 'GenMWhCal','" +ThisDate+ "',"+ThisTime+"," +RealToStr(G11_Cal_MWhacc,12,3)+")");
IF iexec <> 0 THEN
END
SQLEnd(hSQL);
Any help is greatly appreciated. I’m a little rusty with SQL right now and Python is very much new to me so any help is greatly appreciated.
