Trying to import .json object through designer GUI for Tag Import, receiving "Not a JSON Object"
Tag Browser -> Right click folder -> Import -> Direct
Tag errors occurred during tag import
Error_Exception("Error importing tags: java.lang.IllegalStateException: Not a JSON Object:
[{"name":"BA20_v","tagType":"AtomicTag","valueSource":"reference","dataType":"Float4","extraInfo":"V","sourceTagPath":"[MBUS]up1/L1/FUS0-FUS127/FUS2","documentation":"24VDC Supply Voltage Monitor"}]")
I am 99% sure this is a valid JSON object, everything else that I have that loads JSON objects is happy with it. Is this a known issue or am I making a mistake of some kind?
Update: removing the outer bracket and handing only a dict worked, for a single object.
Unbalanced double quotes, at least.
That trailing " is from the error printout
I'm pretty sure you get an object with a structure like
{ "tags": []
When you do a real export.
Yep, that's it. Bad error message, it is a valid JSON but not a valid tag definition JSON. I recommend changing the error to say something like "Not a valid tag object" rather than "Not a valid JSON object". Thanks!
It should be better, but what you provided is not a valid JSON object - it was a JSON array.
