Trying to query difference between rows in table
Long story short in an old 7.8.5 system.
I have a table where I query to populate. I want to get a difference between each row.
Lets say
row 1
row 2
i could have a column that = row 2 - row 1 is x
Here is my current code minus that additional col.
SELECT wastewaterlog.t_stamp AS Date_And_Time,
  wastewaterlog.GrandTotal AS Totalizer_Read_Gallons,
  wastewaterlog.FlowRate / 10 AS Flow_Rate_GPM
FROM wastewaterlog
WHERE wastewaterlog.t_stamp BETWEEN "{Root Container.Start Date.text} 00:00:00" AND "{Root Container.End Date.text} 23:59:59"
i basically want to check totalizer read gallos and indicate how many gallons were added each row.
This is a job for window functions, like lead and lag. What db flavor are you using?
Tried lag and got an error. using MySQL 5.1
Got this code to work. But it takes a little bit to load. Any idea how I can speed it up?
SELECT
    main.t_stamp AS Date_And_Time,
    main.GrandTotal AS Totalizer_Read_Gallons,
    main.FlowRate / 10 AS Flow_Rate_GPM,
    main.GrandTotal - IFNULL((SELECT sub.GrandTotal
                             FROM wastewaterlog sub
                             WHERE sub.t_stamp < main.t_stamp
                             ORDER BY sub.t_stamp DESC
                             LIMIT 1), main.GrandTotal) AS Gallons_Change
FROM wastewaterlog main
WHERE main.t_stamp BETWEEN "{Root Container.Start Date.text} 00:00:00" AND "{Root Container.End Date.text} 23:59:59"
ORDER BY main.t_stamp;
SELECT
	GrandTotal - LAG(GrandTotal) OVER (ORDER BY t_stamp) AS diff,
FROM
	wastewaterlog
WHERE
missing the change gallons in that edit. Just want to verify do I insert that?
I named it diff on a whim, so you can just change it to Gallons_Change
Gave me an error, gotta hit they hay, i'll upload it in a little.
Looks like the window functions in MySQL weren't added until version 8.0. Can you upgrade it?
Negative.
I'd probably create a Stored Procedure in the DB and just call it from Ignition.
SQL Stored Procedures | Ignition User Manual
