Is it possible to read the serial port within a Tag Change Script?
I am trying to monitor a serial port using a Tag Change Script on a tag in a UDT, but I am getting errors on the serial object not being recognized. The tag with the Tag Change Script is an Expression Tag that contains the current value of the time in seconds. The same code works fine within a script on a Button or in a timer script. I have a need to read several serial ports for this application, and I would like to use a UDT to allow me to abstract the logic and then just change the specified serial port in the different UDTs.
I am using Ignition 7.8.1.
Thanks for any help with this.
