Trying to use 3rd party java libraries: error unpacking while loading designer
I’d like to integrate this library https://poi.apache.org/ in my project to read/write Excel files. I copied the following library files and dependencies
into the lib\core\common Ignition path, together with the pack200 processed files
The gateway starts with no error. But when I try to start the designer, I get this error message
and the Java Console reports the following exception
Any suggestion?
Thanks in advance, regards
After googling around I found that xmlbeans-2.6.0.jar has an issue and that is duplicated entries!
Applying what’s suggested here https://stackoverflow.com/a/27649282/1737538 solved the issue.
Many thanks to Daniel!
