Hello. I have inherited a Scada with 27000 tags, that saves them to historian each second. It creates tables of about 20Gb for each day. It uses PostgreSql in a Windows Server 2016 with 32 GB of RAM.
As I said in other post, I had problems with queryTagHistory ( a lot of time outs ). I have checked that removing timestamp index of table and leaving only the tagid+timestamp primary key, the number of timeouts decreases.
But I see that continues sometimes with time outs. I see in the Active Queries of the gateway that the same query of historian charts, sometimes takes few seconds and sometimes 5 or more minutes! Queries of ignition, not custom queries. PostgreSql is dedicated to Ignition in the same server.
Are there any recommended tunings for PostgreSql installation for Ignition? I read that the default installation maybe is poor for Ignition. I would love to, but now I don’t have time to be an expert with PostgreSql. I would appreciate some tips to check, to improve the performance with Ignition, that not have complex queries nor joins, only selects by timestamp and tagid, and inserts.
I promise I will do a report with the solution for future similar questions if I can resolve it
Thank you!
