After each restart of the gateway a Dispatcher error appears in the logs. Error sending SMS; account faulted., SMS messages aren't being sent.
Opening the gateway Config --> Twilio --> Accounts --> (my account) editor and just clicking the Save button fixes the problem and SMS texts get sent.
I was using Twilio module is v3.1.24 (b2023011208), there are the errors.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 16, in valueChanged at com.digitalpetri.ignition.twilio.accounts.TwilioAccount$FaultedTwilioAccount.sendSms(TwilioAccount.java:129) at com.digitalpetri.ignition.twilio.scripting.ScriptModule.onSendSms(ScriptModule.java:24) at com.digitalpetri.ignition.twilio.common.scripting.AbstractTwilioScriptModule.sendSms(AbstractTwilioScriptModule.java:66) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) com.digitalpetri.ignition.twilio.accounts.TwilioAccount$TwilioAccountException: com.digitalpetri.ignition.twilio.accounts.TwilioAccount$TwilioAccountException: Error sending SMS; account faulted.
I installed Twilio module v3.1.25 (b2023021409) and get a new error object has no attribute 'twilio', SMS texts aren't being sent. Looking further I found something in the Config --> Modules for the Twilio module, Faulted Minimum Ignition Version Not Met so I removed it and install the previous version, 3.1.24 and back to the same problem.
Idea's?
