Two gateways with one showing connected OPC and the other shows FAULTED
Hello,
I was curious if anyone has encountered something similar.
I have two ignition servers. Server 1 is 8.1.20 and server 2 is on 8.1.36 (to make use of mitusbishi drivers).
I noticed that the OPC UA connection is CONNECTED when inside Server 1, but FAULTED when inside Server 2.
I went to the OPC connection status and get errors related to certificates and one for an improper user. I am not too well versed in the security side but I did not notice any differences with their respective advanced endpoint setting security mode or policy and no other differences in their advanced configuration.
Below are the two errors, but I was curious if anyone had any leads or experienced something similar? Thanks in advance
  • error (8.1)
UaException: status=Bad_SecurityChecksFailed, message=sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at org.eclipse.milo.opcua.stack.core.util.validation.CertificateValidationUtil.buildCertPath(CertificateValidationUtil.java:413)
at org.eclipse.milo.opcua.stack.core.util.validation.CertificateValidationUtil.buildTrustedCertPath(CertificateValidationUtil.java:120)
at org.eclipse.milo.opcua.stack.client.security.DefaultClientCertificateValidator.validateCertificateChain(DefaultClientCertificateValidator.java:64)
at org.eclipse.milo.opcua.stack.client.security.DefaultClientCertificateValidator.validateCertificateChain(DefaultClientCertificateValidator.java:95)
at org.eclipse.milo.opcua.sdk.client.api.identity.UsernameProvider.getIdentityToken(UsernameProvider.java:162)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.activateSession(SessionFsmFactory.java:925)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActivatingState$19(SessionFsmFactory.java:353)
at com.digitalpetri.strictmachine.dsl.ActionBuilder$PredicatedTransitionAction.execute(ActionBuilder.java:119)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.lambda$run$0(StrictMachine.java:242)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.run(StrictMachine.java:227)
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source)
at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source)
at java.base/java.security.cert.CertPathBuilder.build(Unknown Source)
at org.eclipse.milo.opcua.stack.core.util.validation.CertificateValidationUtil.buildCertPath(CertificateValidationUtil.java:411)
... 13 more
8.1.36 (b2024010211)
Azul Systems, Inc. 17.0.8
  • Error
UaServiceFaultException: status=Bad_UserAccessDenied, message=User does not have permission to perform the requested operation.
at org.eclipse.milo.opcua.stack.client.UaStackClient.lambda$deliverResponse$5(UaStackClient.java:337)
at org.eclipse.milo.opcua.stack.core.util.ExecutionQueue$Task.run(ExecutionQueue.java:119)
