I have a screen with two tables, top one contains data, bottom contains summary info (avg, min, max).
Would be nice if only one horizontal scroll was visible which affected both tables, instead of each having a horiz scroll that works independently . . . any ideas?
Is this even possible?
Also -
The far left column contains the date, ideally this would remain in place while the other columns are scrolled; can selected columns be ‘granted immunity’ from horiz scroll?
(Client wants to be able to add flags and generally edit any cell they choose, so that is why the two are set up as separate tables each linked to a different database table)
Thanks!
Dale
